Re: Isolating cylinder misfire issue
Currently I have an 04 with 0335(crankshaft) and P0300(multiple cylinder is mis-firing)The 0300 did NOT show up on the Key Dance. I am wonder the same as you about the Coil Pack. The mechanic said the Coil wasnt putting out enough and this could be the reason I have blown through 5 sensors in the last 25,000 miles.
In the OLD DAYS a coil was Bad Or Good. The car DID or DIDNT start. In new cars are there varying degrees of going bad?
Did you replace your coil? How hard was it?
