Old 19 Mar 2014, 10:43 am
InfernoGT's Avatar
InfernoGT InfernoGT is offline
Default Re: Transmission Mount
Originally Posted by rcktpwrd View Post
those go into the factory torque links commonly referred to as engine mounts. They take up the extra space in the rubber bushing to help eliminate movement in the mounts. They will add some additional vibration, it not really noticeable with a manual transmission. I installed two sets of them, one in the upper mount and one in the lower mount. The car feels a bit more solid on take off and especially during shifting as the engine doesn't rock back and forth quite as much.
I hear that doing both upper and lower with an auto trans is not advisable due to the increased vibrations, which is only noticeable at idle...
You are referring to the motor mount inserts. There is an insert for the transmission mount as well. There is only one and I believe it goes on the top of the transmission but I have never installed one. I remember looking into getting one for my neon.
2006 PTGT with 5spd. ~60k miles
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
