Originally Posted by randyincctx
The holes are for those zip ties with the square ends,to go thru,and hold the inserts in place once installed.
That brings up another good point, I have heard of the zip ties breaking and then the inserts fall out... you can put long bolts in there instead or go the route I did and get a set of inserts for a Neon. The Neon set comes with inserts for both upper and lower torque struts and bolts to hold them in place. I have Energy Suspension ones...
