Old 24 Mar 2014, 01:22 pm
rg1 rg1 is offline
Default 2007 2.4 Touring - TCM issues? have error codes
Wife was out driving the car and said she couldn't get out of first gear. Engine light was on. When she got home, I checked fluids. All seemed ok. I got in started it up. Saw engine light. I drove it around the block a few times, had no issues with shifting into higher gears.
I got the following diagnostic codes:
P0700 - (General) Trans control system malfunction
P0218 - over temp
P0714 - Tans. flud Temp sensor
P0882 - TCM power input signal
Considering the car seems ok now, should I get it checked out? Could the TCM be going bad? Could it somehow have lost power due to loose connection and then recover? How long will it take for the code to clear?
Any help, suggestions, greatly appreciated.
Thanks.
-Rob
