Old 29 Mar 2014, 01:42 pm
TD2593 TD2593 is offline
Default Re: Engine problems continued
A spun rod bearing will not make a squealing noise (usually), it will start out as a deep thucking noise or rattle when you rev the engine and hold at a steady RPM and get worse as it progresses. Its very easy to mistake for a lifter noise if you are not familiar with spun rod bearings. It is very unlikely that no crank damage is done, almost impossible. You need to have your shop check the run out on that journal and see if its still in spec for diameter to. It is possible that trash got in the oil when the head was removed and caused the bearing failure.
