29 Mar 2014, 07:41 pm
Re: Camshaft sensor and P0340
Originally Posted by cruiser_wa
But, when the car is parked or N, if I push the gas and increase the RPM same thing starts to happen between 3500-4000 RPM. I never this before so I can't tell it started to happen with my incident, or its just normal behavior (though doesn't feel like it).
Are you still getting the P0340 code,or maybe a new one?
I'm not sure if that's the rev-limiter kicking in @ 3500-4000,but I haven't really revved up like that when in 'N' either.
If your still getting the P0340 code,you might want to check the harness from the connection back,and see if the wiring insulation is hardened,brittle,or broken.....
Or if you purchased an aftermarket CPS,there is always the possibility it's no-good right out of the box(fairly common complaint w/aftermarket replacements).
Aka:~KILLER~
