Old 30 Mar 2014, 08:51 am
rg1 rg1 is offline
Default 2007 2.4 Touring - TCM / PCM issue - going into LIMP mode
Hi..the car has 58000 miles. It hasn't been services since I have taken possession. It has been in my family for a while, and nothing major was needed/done.
I spoke with a mechanic about the issue, and the general consensus is the PCM is going bad and nothing I can do.
The problem came back today. Started up, engine light came on, car was in "LIMP" mode. I shut off the car, and restarted, and it was fine. Engine light is still on, but not in "LIMP" mode.
I also found out this car has integrated TCM/PCM, so I cant just replace my TCM (so I am told), and I have to replace the entire PCM. Is this true?
Im not sure what my options are. If I need new PCM, I quess I would just have to do it, but Im hoping there may be other solution.
