Headgasket / Overheating
My '01 PT (N/A 207K miles) developed a cracked in the radiator. i noticed the crack when the PT overheated on way into work. I added some water to get me home, but on the way I had to pull over and add more. About 1/2 way the heat stopped working and before I could find a safe place to pull over the engine died.
When i got home i filled the radiator with water to look for more leaks, I pulled the plugs and turned over the engine and got a water fountain display you would expect to see at a Las Vegas Hotel. Also, courtesy of a loose exhaust pipe, water pouring from the exhaust manifold connection. But, no water in the intake. I started stripping down the engine thinking it was the head gasket.
So, I have the head off and I don't see anything obvious and not sure what to look for. Would a head gasket failure explain the massive amount of water flow? Do I get a new gasket and put it all back together and hope for the best? Take head to machine shop or just give up and buy a new car? PS: First head gasket attempt, have mercy on me. I assumed car is scrap so wouldn't hurt to try.
