Old 09 May 2014, 02:53 pm
Wineaux Wineaux is offline
Default Re: Topping off the hydraulic fluid in the motor for the top?
So, to answer my own questions after having visited a local convertible top repair shop...
1) Yes, you can refill the hydraulic fluid in the PT Cruiser's pump reservoir.
2) At the age of my Cruiser (2005), we should all be starting to see the seals and valves in our hydraulic cylinders (Which are indeed manufactured by/for Mercedes Benz) begin to deteriorate and fail like mine did.
3) Unless you are in the mood for a good belly laugh, or your Cruiser is still under warranty, don't even bother calling your local Chrysler dealership to ask about buying new hydraulic cylinders. They won't just sell you the cylinders. You have to buy not only the entire motor/pump/cylinder/hoses assembly, but a part of the frame of the car that they're bolted too! And what will that cost you may well ask? $2,000-2,500!!!!! Yet again driving home the expensive lessons that I've learned over the years to never ever ever ever ever own another Dodge/Chrysler/Jeep vehicle.
4) That when (Not if, but when...) the seals and valves in your hydraulic cylinders go south, you'll need to find a place that rebuilds hydraulic cylinders. My local convertible top repair shop (Tops Unlimited), has been using a company out of Oregon, but their turn around time is rather long, shipping is slow, and their prices seem a bit steep. I found a company located in Bradenton, FL who will rebuild them for $150/cylinder with a 3 year warranty on the rebuild the same day they receive your bad cylinders, and then ship them back out the next day! I got them to give me a 10% discount per cylinder for turning my local shop onto their business, so don't hesitate to ask them for a "bird dog" discount.
5) Labor on the removal of the bad cylinders, re-installation of the reconditioned cylinders, plus hydraulic fluid is going to run me $384 on top of the $270 to have them reconditioned.
So be prepared folks. Your hydraulic cylinders are going to fail at some point. Mine lasted 9 years. Your mileage may vary.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
