Old 18 Nov 2003, 02:56 pm
Kirby Kirby is offline
The graphics are missing, but this is a snapshot of the Telemetry OBD monitoring readings.
Diagnostic Measurements as of 11/17/03 09:58 PM
MIL Light (OBDII Data) off
Ignition Timing Advance (ATDC) (OBDII Data) 6 deg
Battery (on) 14.2 V
Battery (off) 12.5 V
Calculated Load Value (OBDII Data) 4.7 %
Engine Speed (OBDII Data) 766 RPM
Engine Coolant Temp. (OBDII Data) 199 degF
Intake Air Temp. (OBDII Data) 77 degF
Abs. Throttle Position Sensor (OBDII Data) 14.9 %
Short Term Fuel Trim, Bank 1 (OBDII Data) 1.6 %
Long Term Fuel Trim, Bank 1 (OBDII Data) -4.7 %
Fuel System Status/B1 (OBDII Data) closed
Intake Manifold Abs. Pressure (OBDII Data) 41 KPa
Oxygen Sensor Location (OBDII Data) B1S1 B1S2
Bank 1 Sensor 1 Fuel Trim (OBDII Data) 0.8 %
Bank 1 Sensor 1 Voltage (OBDII Data) 0.605 V
Bank 1 Sensor 2 Fuel Trim (OBDII Data) 100.0 %
Bank 1 Sensor 2 Voltage (OBDII Data) 0.075 V
OBD system type (OBDII Data) 3
Keyon time 945 sec
Run time 1378399 sec
Resets
