Old 27 Jun 2014, 10:01 am
randyincctx's Avatar
randyincctx randyincctx is offline
Lightbulb Re: Flashers/Blinkers not working from switch.
If the fuse that keeps blowing is fuse #18,here is a PT Cruiser with a somewhat similar issue(w/lots of good wiring schematics there):http://www.justanswer.com/chrysler/4...ser-blows.html
You probably should thoroughly inspect the wiring for the MFS connector plug,and the wiring on the back of the fuse block to see if there are any signs of overheating(melted/burnt).....Because it sounds like your getting a ground fault/short somewhere along the pathway of the turn indicator circuit.
Here is a 'pin-out' diagram for the MFS connector plug:
Aka:~KILLER~
