Thread: 2001 PT Cruiser
Old 30 Jun 2014, 04:10 pm
CREWZIN CREWZIN is offline
Default Re: 2001 PT Cruiser
P1684 does not indicate a problem; it's only a status, which indicates that the PCM memory has been cleared within the last 50 ignition cycles.
Check the battery for full power and good connections (no corrosion), coil/plugs for spark. The 2001 has a Schreoder vlave at the end of the fuel rail to check for fuel pressure.
