Old 14 Jul 2014, 07:28 am
CREWZIN CREWZIN is offline
Default Re: Revving a little too high & not dropping quickly
Welcome to the forum. You might want to try cleaning or replacing the IAC (Idle Air Controller). It comes apart for cleaning or just replace it. That has a lot to do with your idle and how the dropping of the revs.
The other sensor is the TPS (Throttle Position Sensor) which can't be cleaned, only replaced. Both sensors are by the Throttle Body.
The other thing: In the first picture are two wires running across the top of the engine. One is the Cruise Control, the other is the Throttle Cable. Make sure both wires are (sort-of) tight (not too much slack) and that the wheel that they are attached to is working freely.
