Old 18 Apr 2004, 04:28 pm
PTCumming PTCumming is offline
Default Installed Stage I
WOW!!! [?]what a piece of cake.... I installed the Stage I PCM in the wifes Touring Edition Turbo Lite in under 20 minutes. The transmission fast learn took about 25 minutes. [8)] The hardest mechanical part was getting that lower right bolt off the mounting bracket. A 1/4 " drive rachet with a knuckle did the trick. Going back on was a bit more difficult since the bolts now have to "cut" new plastic when remounting. Just a bit more time consuming. [:I] Performance is well worth the $$$$ Only complaint it is a bit of a knuckle buster I have the nicks & cuts to prove it. Many sharp edges & plastic cable ties to bite you. [B)] Miller time [^]
Dave
Cumming, GA
