Old 24 Aug 2014, 02:55 pm
ptcruisersteve ptcruisersteve is offline
Default Re: PT cooling fan actuating temps 04 PT
Originally Posted by Jgriff View Post
At what approximate temp or gradiant on the temp gauge do the PT not turbo cooling fans start to run? I have just replaced all cooling system parts including a new timing belt, radiator, water pump, thermostat and housing. The car starts and runs fine, but the fans aren't coming on. I have jumped the relay sockets number 30 and 87 on both hi and low speed fans, and both speeds work fine. The sensor at the thermostat housing is working fine too. Any ideas?
Is there a fuse in the fuse block for the coolant fan?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
