Old 24 Aug 2014, 03:11 pm
ptcruisersteve ptcruisersteve is offline
Default Re: PT cooling fan actuating temps 04 PT
Originally Posted by ptcruisersteve View Post
Is there a fuse in the fuse block for the coolant fan?
I believe that the fan is suppose to come on if you take the wire off the temperature sensor? Was the air bleeding procedure was done after replacing the coolant?
