Old 01 Sep 2014, 10:34 am
Default Re: Stuck Starter? Clacking / Ticking...
If your moving trips were short, probably not enough distance to restore the charge you took out of the battery to start the car, so after a few trips, the battery was drained
Radio is often ignition switch - also try moving tilt steering wheel, sometimes it's a connector in steering column that gets pulled.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101
