Old 03 Sep 2014, 09:37 pm
nomad327 nomad327 is offline
Default Re: A/C lines and the Water Pump
I assume you know the entire front of the engine needs to be stripped down to get to the water pump and it is driven by the timing belt that has to be removed as part of the process.
There are many people here who have done the timing belt job without unhooking the A/C hoses. I have personally had the suction hose that connects to the top of the A/C compressor fail twice when doing maintenance in the general area. Once was a power steering pump replacement and once was a thermostat replacement. When I did my timing belt I pumped down the A/C system and unhooked the hoses and that time at least, I didn't damage and have to replace the hose.
