Old 28 Sep 2014, 10:12 pm
dalandon's Avatar
dalandon dalandon is offline
Default Re: My sad story of the instrument panel wiring hacked up
Originally Posted by Handy_Cruiser View Post
There's some 2nd Gen PT's starting to show up in the salvage yards. You definitely want a used harness if you can get one. It should be under $50 if you pull it yourself. That is a whole lot cheaper than the dealer.
Also, it's very possible the hack job was done by technicians when the GPS tracker was installed. Sometimes they have to bypass a lot to get the kill function to work right. And those techs are often actually custom stereo guys. Too bad you can't just patch all back together correctly following a wiring diagram. That's what I would try first.
yes im sure its a stereo installer that did it, i found the wiring harness diagram but its 01-04
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101
