quote:Originally posted by yobiebs
I have a 10-disk changer that currently sits on the floor of my trunk, so i would have to relocate it if I were to do something like this (which I really REALLY want to do). Any of you guys relocated a changer? Where? Under the front seats? Would it fit in one of the side panel pockets in the trunk? Let me know what y'all think....
Biebs
Woot! I made a sticky worthy post!
Unless the dimensions on your changer are ungodly you shouldn't have any trouble at all fitting it under the driver seat or passenger for that matter if you don't have or don't mind losing the drawer.
Having played with routing the wires in the back end of the car I'd say even if you've got a tiny tiny changer you'd be hard pressed to fit it into the rear passenger side interior panel. The driver side though you can probably do if you don't mind cutting the panel some. Remember the "hidden" mopar enclosure fits in that same space plus I've seen folks posting that they have fit larger than 8" sub units in there so it should allow for a changer. Ventilation would be a little limited though so take that into consideration if your particular changer tends to run hot. I haven't given it a hard look so I can't give you any particulars but I think you can make it work without too much trouble.
