Thread: atx controller
Old 23 Dec 2014, 05:24 pm
NitroPT NitroPT is offline
Default Re: atx controller
There is a misunderstanding about the "Quick learn" process with regards to STAGE 1 PCMs?
This process was for older STAGE1 PCM upgrades not the current ones unless the supplier states it is needed. It DOES NOT improve any shifting characteristic as that was already done in the TCM Calibration portions controlled in the STAGE 1 PCM.
You can not get a STAGE 1 flashed into any PCM at a Chrysler dealership that I am aware of? And if they were capable you would not need to perform the "quick learn" process for it.
The cooler is great idea the shift kit you probably won't feel any difference but it will extend the life of the transmission. The reason is because your 41TE has a TCM that is controlled by the PCM and notas much by mechanical component changes as compared to a Torque flight or 727 "old school" transmissions.
You would be advised to change your external Chrysler A-604 (a/k/a 41TE) solenoid pack on the side of the transmissions as these are updated which can help prevent shift or other transmission issues.
STAGE 1 PCM through FWD are available as they find cores and have them serviced checked. Currently they have none in stock with about a 3-6 back order. They are not discontinued.
The availability of some specific model PCM from Syked must be checked as well.
Core availability from both sources if always a questionable challenge.
