Thread: Leak?
Old 06 Apr 2015, 10:54 pm
Default Re: Leak?
Originally Posted by denab View Post
Do not know what color it was ...dark outside now and on asphalt. A/C-defroster not on.
at stop lights noticed temp gauge lowering!?
Don't drive it again until you check coolant level - when engine is cold, open radiator and look in - coolant should be up to brim.
Your temp sensor may have been in air, not coolant, and air does not conduct heat as well, so it reads a lower temp.
