Old 11 May 2004, 11:17 am
snakepitt1 snakepitt1 is offline
Default Transmission fliud - B&M Trick Shift or not?
Has anyone replaced their transmission fluid with B&M Trick Shift, or similar "performance" type transmission fluid?
Also, transmission filter change.......
Is there a better filter than the stock one that comes on our fine autos? I am interested in the best filter I can find that will provide max flow while continuing to provide required filtration.
Also, is there a deep trans or other trans pans available? I had replaced the trans pan on a TH400 with an aftermarket pan that incorporated cooling fins and thru tubes to provide additional cooling. I drive mainly at highway speeds over 1400 miles a week, every week and summers here in TN tend to be very hot. Any additional cooling I can provide for the transmission will prolong its life and reduce the potential pain in my pocket.
Thanks,
Scott Harris
2003 Black Touring Edition - cold air intake and MagnaFlow muffler
