Thread: Changing ATF?
Old 06 May 2015, 08:24 pm
postbeauty postbeauty is offline
Default Changing ATF?
2006 touring non-turbo, 98K miles
The manuals says changing atf is not necessary under normal usage.
However, I noticed the trans jerks when shifting from 1st to 2nd gear, other gears are fine.
Another situation is , when I slow down, say when making a turn, then I press gas pedal to accelerate again, the jerk is very strong, just like being kicked by someone from the back.
Is the transmission dying?
Should I change the atf to mitigate the jerks?
any suggestion is highly appreciated
thanks
