Thread: Changing ATF?
Old 07 May 2015, 07:28 am
Busted_PT Busted_PT is offline
Default Re: Changing ATF?
Originally Posted by BigAng View Post
Hi 767!
Do you use RTV on the pan? Or have you found anything that works better? Seems like well cured RTV still allows fluid seepage.
Thanks!
BigAng
2002 Touring Edition
122k and counting!
Need to use a rtv that is compatible with trans fluid I have read. Also if you clean mating surfaces with certain chemicals. That will cause the atv to not seal. maybe Mel can tell what he uses.
