Thread: AC ?
Old 10 May 2015, 07:53 pm
rob342 rob342 is offline
Default Re: AC ?
If you see the compressor cycling on and off repeatedly, that indicates you are slightly low and you could just get a small can. Just add it until the compressor stays on and stops clicking on and off. Don't add the whole can.
Avoid the AC pro though, just get straight cheap r134a with no added dye, oil, or leak stop crap.
Using the $24 method and holding the gas pedal to 1500rpm, i managed to get my ac to 47*f measured with a thermometer in the center vent. I believe closer to 40 is ideal, but only someone like nitro could tell you something like that. I'm not a mechanic.
