Thanks to everyone for their input. 3Bar, thanks for your input. You again provide some good solid information that is more than "it just makes it sound good." I now need to perform some analysis (the engineer in me) to really see if there is value in spending the bucks. It sounds like there may not be value. I will have to make up my own mind up on that one.
[img=right]http://members.cox.net/azptcruiser/PTCRUISER/AZPTCRUISER%203.jpg [/img=right]
BTW, IRPT, I reverse designed from the original rubber molded piece. Then made on a rapid prototype machine. Can customize the top surface to add any graphic that I can import into my CAD system. Material is ABS which can be finished in almost any manner. Will do that next!
