Old 24 May 2015, 09:07 pm
Triplesevn Triplesevn is offline
Default 2006 PTC Power Window Motor *Wire*
My driver side power window went down and never came back up. So I removed the door panel and inspected the wire first. As I moved it a bit (and no, I didn't disconnect the battery), I pushed the button and it moved up.
The problem is the wire is spliced open at the connector point of the motor as well as a little bit at the main connector. (See attached photos. Second photo in first reply)
My question is, is it possible to ONLY replace the wire or do we have to buy the entire PWM assembly? And if so, where could I purchase this, besides a junk yard?
Last thing; my DumbA broke the white plastic piece that helps open the door from the inside. It's the piece the rod connects into and swings around when pulling on the inside handle. Can I buy just that piece or have to buy an entire door assembly?
Thank You in advance for any and all help.
