Old 30 May 2015, 04:37 pm
pasadenahotrod03Dreamer pasadenahotrod03Dreamer is offline
Default Re: How to get power window down in junkyard to remove it?
To remove the door panels, first remove the triangle trim at the rear view mirror. No need to remove door lock knobs, leave them on.
The use a Phillips head screwdriver and remove the screw inside the door handle opening and around the edges of the door panel where you see cutouts.
The using the appropriate size Torx bit remove the two screws holding the arm rest to the door.
Now pull back on the edge of the panel give a sharp pull outward. This will pop loose a couple of the six or eight bullets that hold the panel to the door. Move around the panel down across the bottom and up pulling the panel free.
Now hold the arm rest and the front edge of the panel and pull upward slightly to free the top of the panel and lift it off the lock knob.
Once free it will pull out six inches or so so you can unhook the door lock wire plug and pop the latch off the door handle rod and pull it free.
Now set the door panel aside and get to work, nothing bent, nothing broken. Reverse steps to install.
