Sakigt, if you are running 15 lbs of boost, and went to pass someone with going W.O.T. then you will get that burp and your eng lite will came on, p1188 over boost, at 1/2 throdle, before you go to the dealer disconnect you batt for 2min. this will reset everything and no eng lights will show up on the dealer's computer check of you car.when you get your car back back . disconnect the little hose just before the throdle body ( 1/8 black pastlic hose next the elect conn. on the inlet 2 1/2 hose going into the throdle body, you will fool the computer in to thinking you only have 10 lbs of boost. No more light, yet you may still get one if you r in mid range and increass speed at 1/2 throdle and hold that for 10 to 20 seconds, example 30mph and want to pass , you ease up to 35 then 40 then 45 you will get a eng light or burp or both best thing to do is floor it then let off when you get half way pass the other car, your speed will carrier you the rest of the way,.
jim
