Thanks Gary,
As I suspected it was actually the paint that was gone. The good part is that once I followed your instructions the transition is so faint that it doesn't bother me at all. There is almost no variance in colour between the painted and no painted. The only way you can there is a difference is where the edge of the paint is. The cleaning with Fantastic reduced to just the paint depth now rather than before when it had balled up along the edge. I'll get the wheel installed tomorrow while its in for service.
Again thanks for your help.
Steve
quote:Originally posted by turbomangt
I see someone is listening to me, that was my post on dyed leather. Here is a test to see if your leather can be saved. Use a PH safe cleaner and a small nylon brush (like a toothbrush is fine) try someting like simple green or fantastic (spray a little on the brush) the gently rub the area. if it improves, then you are home free, finish up with some conditioner. If not, then it is likely that the dye has been removed and the color has to be redyed again, that in the job of an interior shop. I think you might get it done with the first option. let us know, gary
