Old 17 May 2004, 10:51 am
Dragula Dragula is offline
Default Mopar BOV installed.
My thanks to those who stated that a ratcheting box end wrench was the ticket. I bought one ahead of time, and it was easy. I did struggle with the oil line, but I got everything from topside. I was even able to use an inch pound torque wrench to torque the two outside bolts to spec (in the instructions). The other had to be torqued by feel.
One thing that I think is important is to make sure there is clearance between the oil line and the bolt AFTER the installation. Mine was rubbing. I was able to bend the line just about a quarter inch away from above. You don't want to have that bolt eat through the oil line.
Note: If I had bent the oil line ahead of time it would have been much easier to start that one inside bolt.
