Old 13 Dec 2003, 09:59 am
hyracer hyracer is offline
You might direct your question to 3BarBoost
I spike at 15 lbs. now with S1 and I'm guessing S2 will be pushing us to 16 lbs. with a spike a little higher than that. There is no indication from Mopar that you'll need to change the headbolts for S2 or S3.
Deen
