quote:Originally posted by 98 Neon Driver
Beacon, what is the availible mounting depth for the subs? The box has enough volume to mount a pair of Fosgate HE2 12s, I was just wondering if it had the depth if the openings were enlarged for the 12s
AC
Top mount depth was 6 1/4" approx. I'll have to go out and double-check, it'd be close but you could probably enlarge the mounting hole to accept 12's. Only problem would be the ABS lid. With the 10's you've got about 1/4" between the outside edge of the speaker and the lid so you'd either be laying the lid on top of the 12's or you'd have to cut the lid out to accomodate the increased rim size. Which would most likely be the preferred way to go as you'd have some serious vibration issues if the lid was resting directly on the rim of the 12's. I'll run out and take some more measurements and post it later.
