Old 16 Dec 2003, 08:44 pm
skylight's Avatar
skylight skylight is offline
Administrator
TSB# 18-029-03
Date: August 8, 2003
SUBJECT: Slight Engine Mis-Fire Above 5200 rpm
OVERVIEW: This bulletin involves replacing the Powertrain Control Module (PCM).
MODELS: 2003 (PT) Chrysler PT Cruiser
NOTE: This bulletin applies to vehicles built prior to January 22, 2003 (MDH0122xx) equipped with a 2.4L Turbo engine and manual transmission or prior to March 18, 2003 (MDH 0318xx) for vehicles equipped with a 2.4L Turbo engine and automatic transmission.
SYMPTOM/CONDITION: Vehicle operator may describe a random or slight engine mis-fire when operating vehicle above 5200 rpm. There will be no DTC logged in the PCM. If there are DTC’s present additional diagnosis should be done to determine the problem. This condition is caused by a internal hardware issue in the PCM.
