pull your codes, use your check engine light. get your key, put it in the ignition, turn it to on (lights on dash come on) then off, then on, then off, then on, and leave it on, never crank the motor.
So to simplify On-Off-On-Off-On
Then read the numbers that come up in the odometer display. It should start with a P and have 5 charecters total.
Let us know what they are. if you couldn't get them all fast enough, do it again. If you have no codes, it will say "done"
If your light is on anyway, you have set some code(s) and are into a limp in mode most likely.
88 Daytona Shelby Z T-II Blue
88 Daytona Shelby Z T-II Silver T-Tops
89 Caravan ES Turbo-I
03 PT GT Turbo 41TE Autostick Electric Blue
