Old 10 Nov 2015, 10:40 pm
bob2006 bob2006 is offline
Default Re: EVery winter it's the same..
Until you solve it or sell it, try keeping a charger/trickle-charger on the battery every night.
http://www.amazon.com/s?ie=UTF8&page...ckle%20charger
Sure beats being late to work every morning.
What kind of temperatures are seeing out in Colorado this time of year.
It seems pretty early in the season for your battery to be affected by cold.
Are the terminal connections tight?
It doesn't take a great deal of mechanical skill to check.
Pop off the air filter cover for access to both the positive and negative terminals.
Make sure the terminals are clean and the ring clamp that holds the wire to the terminal is a turn or two past snug.
I hope you get it figured out soon.
