Old 01 Jan 2016, 01:30 pm
NitroPT NitroPT is online now
Default Re: I need to replace the gas filter. What should I buy exactly
It is a fuel pump screen and can be replaced but then you may as well change the pump while you are there.
The screens rarely get so dirty that they need replacing and if they did your pump was probably on the verge of failing anyway?
As I have often said in the case where a "mechanic" is giving this kind of advise specifically about a PT Cruiser it is time to shop for a better mechanic or Auto Technician.
