Old 01 Jan 2016, 01:57 pm
rckstein's Avatar
rckstein rckstein is offline
Default Re: I need to replace the gas filter. What should I buy exactly
Are you the original owner to the vehicle? Do you frequently run your tank nearly empty before refilling? If so, that is not a good thing as the in-tank fuel pump uses the fuel as a coolant. There are some pressure and flow tests your mechanic can perform. But if it is a fuel pump issue, either way the tank has to be dropped, and if you do that, you might as well replace the pump rather than try any kind of repair to the existing, especially with the number of mIles your PT has.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
