Thread: Cut off
Old 05 Jan 2016, 12:19 pm
Busted_PT Busted_PT is offline
Default Re: Cut off
It has to be a power issue. If starter won't ingauge. Anything in the Circuit is suspect at this point. Ignition in the column should not be because it stopped running while it was still actually running. I would check the wires on the starter specially the little one on the side. Check for continuity on these wires back as far as you can trace them. Just for grines and giggles. Try jumping the starter. Make sure you have a strong battery. But I don't think that is your issue.
