Thread: Cut off
Old 05 Jan 2016, 09:27 pm
ptcruisersteve ptcruisersteve is offline
Default Re: Cut off
I would suggest first taking a voltmeter and see if you have 12 volts coming from the ignition switch to the starter.
If you don't have 12 volts coming from the ignition then you need to see if your security red light is on on the dash. If your security red light on the dash goes out after 3 seconds when you are trying to start it it should be okay.
Did you try starting it in neutral? Your neutral switch might not be working properly.
Post what you find out and we can suggest more troubleshooting ideas.
