Old 22 Dec 2003, 10:45 am
MX-5 MX-5 is offline
You did not test the engine codes, you tested the instrument cluster self-test. Those 'codes' are only the software revision level of the BCM body control module.
You must turn the ignition key from off to on 3 times quickly, ending in the on position. This will read any PCM engine codes.
