Old 05 Jun 2004, 03:44 pm
PTGT Redman PTGT Redman is offline
Default Funny (now), but typical for me
I tried installing Adam's UCP last night, but got tired after a while (long day), so decided to reinstall the stock UCP. For some reason I seated the intercooler side first. I put the grommet in the upper part of the pipe and started to nurse the sensor back into the grommet. Pop!...went the grommet, which I heard bounce down the length of the UCP. I pulled out the UCP, desperately hoping (to no avail) that thr grommet was still in the pipe. No grommet. I figure it must have gone into the intercooler outlet. So, in search of a 3 cent grommet, I had to remove the nose of my car, unbolt the lower radiator mounting bracket and unbolt and remove the intercooler. Found the grommet (had to turn the damn intercooler upside down)and then bolted everything back together. Well after the teardown, I was depressed as after 4 hours, my car looked exactly the same as it did before I started. Only perk was that I reset the PCM after having the battery unplugged so long.
Seems whenever I start one project, it turns into a PROJECT.
Figure I'll take another try at the pipe, or at least install the intake pipe.
Fun[^]
