Old 10 Jun 2004, 06:50 pm
pt pete pt pete is offline
Default boost pressure runnung mbc
Just kinda wondering what normal boost pressure readings have been for others running a mbc valve? When i installed mine i took it out and did several test runs and finally settled on running the mbc with a dead stop run, auto stick in manual mode, the boost will hit approx 16lbs and then settle down to 10-11lbs after 1st gear.. Does this seem normal or should i be seeing something different? The biggest difference the mbc made was spool factor, it seems to spool up much quicker than before and final run pressure may be about 2 lbs more than stock...I was hoping to see the boost pressure stay at around 14-15lbs all the way through my runs, is this possible? Any input would be helpful thanks, pt pete...
