Old 28 Dec 2003, 12:50 pm
kevinl1058 kevinl1058 is offline
Randall as stated above, first off what is the offset of the 20's that you are running? Secondly the plastic ring the comes with most wheels now is used to center the wheel on the hub. Third if you have the too spare you might want to go with a 1/4" wheel spacer..
The biggest problem that I think you may have is the spring perch coming into contact with the tire.. Most people that have tried to go with 20's up have had to raise the spring perch to accomodate the larger diameter tire..
If you go with a strut bag set up there is still a possibilty that you will have to modify the perch as well for clearance purposes.. If you were to go with cylinders like I did up front you will have to add a spacer to clear the larger diameter cylinder..
Hope this helps..
Send me some pics via email and lets see how we can fix your problem..
Kevin
