Pt cruiser won't stay running
My 01 pt cruiser will not stay running it starts and if I get lucky it stays running for about 30 seconds. It 80k miles on it and is a automatic. Non turbo
All fluids are good. I did a fuel pressure check off the fuel rail and it was all good. I also did a check on spark plugs, coil pack, and spark plug wires and they were all good.
I am now doing compression checks on all the cylinders. I did it and they all held pressure I am going to redo the test and give you guys numbers tomorrow. And sense I can't do it while at optimal temp. I am doing it with the engine cold.
I have not checked the fuel injectors. The car runs for 20-30 seconds which is making me stumped on what the problem could be.
Any thoughts or ideas?
