Old 14 Jun 2016, 12:26 am
SpannerHound's Avatar
SpannerHound SpannerHound is offline
Smile Re: Pt cruiser won't stay running
That doesn't sound great. Lots of air bubbles at the radiator just on cranking could be nothing more than some trapped air in the cooling system, but it's pretty unlikely imo. Coolant being sprayed out of the plug holes, however, is a whole other matter. If that's what it is, it would be a sure sign of gasket failure at the least, perhaps worse.
A proper coolant system pressure test should highlight any leak, but if you don't have the equipment, a quick 'n dirty trick would be to use a compressor with a jet nozzle/ tyre inflator and just squirt some air blasts into the overflow at the rad cap. Don't go mad with it, just a couple of little blasts is all you need. Make sure the coolant is topped up first so the system is full. If it's leaking anywhere, you will usually either see it immediately, or at least hear it escape and be able to track it down
