Old 14 Aug 2016, 04:03 pm
ptcruisersteve ptcruisersteve is online now
Default Re: Rear hatch lock on Gen 2 Turbo not working
Originally Posted by rckstein View Post
I don't believe you can get the door panel off, with the liftgate closed, as there is a button pin at the bottom edge that has to be removed, and since it is on the bottom edge of the liftgate, it's not accessible.
You can start at the top of the inner trim panel by removing the CHMSL cover panels with a trim stick C-4755 or equivalent flat bladed tool to disengage the snap retainers that secure the CHMSL cover panel. After you get the top panels off then you disengage the retainers holding the upper part of the lower trim panel to get enough room to get to the switch. Its not easy and you have to be very careful not to damage the panels.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96
