Thread: injectors
  #15 (permalink)
Old 02 Sep 2016, 01:18 am
_PTGT03's Avatar
_PTGT03 _PTGT03 is offline
Default Re: injectors
Originally Posted by CREWZIN View Post
From what I remember, Chrysler put the lager injectors in the Turbo Lite cars in 2004 so that's why the Stage one from 04 up only needed the computer upgrade where as Stage 1 for the PTGT in 2003 also needed to add the lager injectors.
2003 PT GT come with 527cc injectors.
2004+ PT GT's and Lite's come with 577cc injectors which are required for Stage 1.
The percent change of 527 increasing to 577 is
(527/577)*100 = 100-ANS = %8.7
really worth the cost ? not sure. without real dyno numbers, you don't actually know if the stage 1 really required these.
one can easily get compatible and cheaper, larger capacity injectors off ebay that would go much farther for performance enhancements.
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings 3" exhaust elbow, Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
