Re: Overheating like so many others!
Originally Posted by shamilton84
Hi all! This may be long so please bear with me. I have a 2007 Cruiser that's driving me crazy. It started overheating and the AC would blow hot. I replaced the radiator fan and thermostat because those were the cheapest and easiest fixes. It worked for 3 months then stopped. So I figured the fan was crap and got another replacement. This time, it died the same day. So I don't know if I'm just having the worst luck with fans or if I need to delve deeper. The symptoms are as follows: the check engine light came on for a couple days this time but has since gone out, it idles rough if I turn on the air and blows hot, the rpms drop significantly when the fan tries to kick on and of course the temp gauge keeps climbing if I'm not moving. I've read so many other threads and nothing seems to match my stupid car so I'm hoping someone can shed some light on this for me. Thanks for any help!
Check the wiring harness connector to the fans for damage inside the connector, also check for voltage when the fan should be on.
If you over heat the engine you will have more problems than you want to deal with.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
